A Pontiac 400 will slip right in BUT you must use the 301 mounts. The rubber clamshells that bolt to the frame are easy to get but the perches that bolt to the block are not so easy to find. You want the '78 to '81 265/301 LeMans/Grand Prix perches. Ebay is a good source, Craigslist, etc. Firebird or other model block perches will physically fit but will raise the motor a few inches. What year is the block? The blocks with the five or three bolt holes in each side are the easiest to use. Earlier two hole blocks you will need an adapter available from the big vendors. I once bought the perches at a real parts store. But since they are not a "wear" item, they don't make them anymore.
