Pontiac Snowflake wheel differences
PBGBodyFan
792
1,223
Wisconsin
What version of the snowflake wheels was optional on the g-body Pontiac's? Also what years/models, if anyone has that information.
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,509
4,902
Rolla, MO
AFAIK there were only the 14x6 and maybe a 14x7(?). The 15" were F body, but they'll supposedly fit. There were 12" 4 lug versions for the sunbird, too.
This image is for '79 only, so other years may be different.
full
PBGBodyFan
792
1,223
Wisconsin
Awesome, thanks!
Will be on the lookout for a 14” set(not just because that’s what size they came in). Any differences in the g-body or f-body versions?
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,509
4,902
Rolla, MO
PBGBodyFan
792
1,223
Wisconsin
Perfect. Thanks again!
1evilregal
3,056
4,357
Greensboro, NC
when I picked the up, he was wearing a set of hard worn 15" snowflakes. the fronts were setup normally, but the P.O. had a set of 1/8" spacers behind the rims.... they had several chunks missing around the edges, so I never really tried putting them back on without the spacers.....
565bbchevy
9,611
12,670
Michigan
You can always get new aftermarket 15" x 8" snowflake wheels, I think OER and US Wheel make them.
PBGBodyFan
792
1,223
Wisconsin
Picked up this set for $250, 15x7 the “Western” style if you look at the different versions around, very clean off a Nevada car. Need a couple center caps and might change the gold to black or make them all silver, not sure yet but went for 15”s over 14”s. Test fit on one Monte Carlo, barely clears the outer tie rod and UCA (has SC&C uppers). A small spacer would help give ample clearance I think.
