posi clean up
I just cleaned mine up, I used duplicolor semigloss high heat black, with duplicolor high- heat primer underneath, and it came out ok. If you want to get crazy, you can use SEM high heat from the paint shop, or if you really want to go nuts, use POR- 15, then top coat it in chassis black.
I used good old fashioned industrial rustoleum on mine, it's held up great.
Thank you sir
