My '82 Grand Prix's original 4.1L V6 engine apparently was replaced before I purchased it. The car's odometer was not working when I got it, so not sure how many miles are on her, but it does say 101,623 now. A mechanic figured out that the current engine is a 3.8V6 as when he was going to replace one of the cooling system hoses the 4.1 one didn't fit. The car has a DualJut carb instead of the 4-BBL that came with the 4.1.
Don't drive the Grand Prix much and it doesn't seem to use oil or have any blue or white smoke coming out of the tailpipe (thank goodness!). Of course, don't know how many miles the 3.8 has on it. Am wondering if I should have the engine compression checked and spark plugs looked at to determine the true condition of the engine? The factory A/C drive belt is missing as the compressor clutch pulley scrapes against the compressor, so that must have needed replaced long ago. Need to have A/C as the heat really bothers me.
My question to everyone is depending on the compression test etc., should I replace the 3.8 V6 will another one (to keep the factory A/C, radiator (which has been replaced), current accessories i.e. alternator etc.) or put a 350 in with an Edelbrock 4-BBL carb.? If the engine needs replaced, then the automatic transmission would probably need to replaced as well especially if a V8 is installed. The torque converter seal is leaking and needs replaced for the tune of $500 I'm told. Don't know what rear end the car has. I plan on keeping the car forever, so want to make it more reliable. It's not left me stranded so far, but so don't want that to happen.
The plan is to make the car a "street version" of Richard Petty's G-Body Grand Prix, as I saw him win the '83 Winston 500 in person at Talladega Speedway on May 1, 1983! The interior would stay stock. The paint job would look like Richard's. My budget is limited, so can't go "wild" on modifications, etc. I don't mind the V6, but don't know if the 3.8V6 is "bullet-proof" or not.
Thanks.
Maggie Ann
Thanks.
Maggie Ann
