OK, finally went through this car I got about two months ago. Completely stock 85 GP 5.0 with Qjet computer carb on it. Car has 95k original miles, bought it from the old lady with a box of records. All the plugs that came out went back in, they all looked great, just adjusted the gap. I bumped the timing to about 6-8*. Had the radiator repaired (soldered) by a local shop. I did an oil change on it also. I've been running the engine and letting it warm up and drive around the block, but no actual driving since I bought it. I've been flushing out the cooling system and am starting to get worried. The overflow tank is all sludgey. So I disconnected it for now. I'm getting a brown rusty oily goop after warming it up. Each time I do a flush and fill it's less and less each time. I did flush it out for 2 days with 1 gallon of vinegar and warming it up a few times.... man did that flush the system out. The oil looks squeaky clean, the crap in the radiator is a brown oily sludge that is floating to the top. I figured if I was getting oil into the coolant, it would not be brown rusty looking sludge, it would be the clean oil I have in the engine. Car runs great, has no other signs of a HG issue. I have a feeling the oil lady or an idiot mechanic dumped oil into the overflow tank at some point. Plugs, compression and oil look spot on. Again, seeing some minor rusty looking gunk float to the top of the radiator water..... It's either a HG or I knocked some crud loose! Looking for some fellow input.
