Power brake booster swap
D
Doug Chahoy
1,940
Cardone refunded my money because they can’t send me the Caprice power booster for the Blazer brake swap #54-71040 . Any suggestions with part numbers on an alternative?
D
Doug Chahoy
1,940
Why not just use the G body dual diaphragm vacuum booster? Many guys have used it on brake swaps with no issues.
I’ve got a 79. I think I read that if I go that route I should get one from the later years, right or wrong?
565bbchevy
565bbchevy
7,422
Michigan
On my 83' Monte I am still running my factory 9" dual diaphragm booster with my Wilwood's, it works well and clears my BBC.
Reactions: kiko and Longroof79
M
malibudave
114
Houston, TX
Here is the link for a b-body conversion using 12" dual diaphram booster from a 1990 Caprice along with a right hand drive, postal, S-10 master cylinder with a 1.0" bore, it should be significantly better than the stock setup.
S10 1.0" bore Right Hand Drive S10 link
gnvair
gnvair
656
I had 12" b body front brakes on my GN with a standard g body dual diaphragm booster with a larger bore B body master cylinder. The pedal was right "there" and would put you through the wind shield with too much pedal pressure. I never saw the need of a larger booster unless you fall victim of the bigger is better mentality.
gnvair
gnvair
656
Also note that you can tailor the pedal feel via master cylinder bore size.
Larger bores requires more pedal effort but has shorter travel.
Smaller bores require less pedal effort but can have a longer travel on the pedal.
I would highly recommend using the G body booster first before experimenting with the b body booster. You will most likely be quite happy with it.
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,982
Socialist NY
Why exactly CAN'T they sell you a booster??
Thread starter Similar threads Forum Replies Date
Mr.1980 Emergency Brake Cutting Power Electrical / Ignition / Starting 4
CopperNick MONTE CARLO Power Steering Box Q. Wheels / Tires / Brakes 11
S Power steering General Discussion 1
Happy camper manual to power winows ? Body / Trim / Paint / Glass 4
MrSony Engine Dyno vs Chassis Dyno Power Gains Differences? General Discussion 5
rona FOR SALE NOS Power Antenna G-Body Parts For Sale / Trade 2
GPspeed Power steering pump hitting power steering gearbox Frame / Chassis / Suspension / Steering 13
J EL CAMINO Eletric power steering?????? Chevrolet El Camino / GMC Caballero 1
R HELP 07 silverado fuel pump power issues Non-G Projects 16
RideOrDieRegal84 Power window failure Electrical / Ignition / Starting 12
dft Confused on Power steering pump G-Body LS Swap 4
565bbchevy 71' Cutlass power sunroof option? General Discussion 4
Bonnewagon Electric power steering General Discussion 6
carnutjw Power steering cooler Frame / Chassis / Suspension / Steering 12
J Power window switch wiring Electrical / Ignition / Starting 2
8 Cimmaron passenger power seat trim G-Body Parts For Sale / Trade 0
7 Cutlass 60/40 power seat tracks G-Body Parts For Sale / Trade 2
8 Power Mirror Upgrade How-To's / Knowledge Base 25
SSpev Power Window motor Electrical / Ignition / Starting 3
M So recent 1984 Cutlass H/O and the power door locks lock but, don't unlock. General Discussion 5
69hurstolds CUTLASS Power Window wiring diagram adding relays to speed up the window motors How-To's / Knowledge Base 33
QuintLee92 Power windows Electrical / Ignition / Starting 31
Z CUTLASS Power steering pump in the way General Discussion 26
GN-Finland Monte Carlo special high power models Chevrolet Monte Carlo / SS / Malibu 37
J power antenna???? Electrical / Ignition / Starting 2
Chuck Cole Crappy old Bench Seat to Power Buckets Chevrolet El Camino / GMC Caballero 4
Anubis POWER NATION - Regal project General Discussion 28
carnutjw 2020 Hot Rod Power Tour Events 24
yaahoos Drivers side power window n/w Interior 3
565bbchevy Jumping power window switch Electrical / Ignition / Starting 4
T Power antenna bracket Restoration 9
T from power to manual stering conversion Frame / Chassis / Suspension / Steering 34
J 83 cutlass supreme 307 y code- power steering bracket Frame / Chassis / Suspension / Steering 6
565bbchevy Aftermarket Power Moonroof General Discussion 1
S Power Steering help New Users 0
pontiacgp Power Window Switch General Discussion 14
C no power door locks? Interior 24
DoubleV Power seat motor Interior 6
B Can I use an antenna windshield to replace a broken power antenna? Interior 24
Y No Power To Starter Wire Electrical / Ignition / Starting 28
abbey castro MONTE CARLO Power Source in the Engine Compartment G-Body Build Threads 6
D New member / question on power seat New Users 0
mclellan83 Pittsburgh Pizza Power Tour Events 32
D Plastic coupler for power seat motor Interior 9
Stupidquestionspro HELP Exploded plastic power seat Interior 0
CaliWagon83 REGAL Power Window Regulators - Same or different between coupe and wagons/sedans? Body / Trim / Paint / Glass 3
David.C Power Steering Gear Box Adapter fittings Frame / Chassis / Suspension / Steering 9
MrSony Power Nation (formerly Power Block) airing classic episodes on YouTube! General Discussion 1
S What power steering gear box on my 1983 H/O? Oldsmobile Cutlass / 442 / Hurst/Olds 2
Kmmurray73 CUTLASS Power chip Oldsmobile Cutlass / 442 / Hurst/Olds 24
Similar threads
