i have a thumper series cam inmy sbc and my vacuum is crazy low. Compcams says that an electronic vacuum pump will probably be needed. I have an air canister but no vacuum pump and my vacuum at idle is less than 7". I know I need a vacuum pump
My front brakes cannot hold past 2200 Rpms without giving. I have a custom built converter for my car that is a 3000 rpm stall. My car hooks great with the mickey Thompson et street R's but I'm looking for a little bit harder of a launch.
A brake booster needs 18" of vacuum to function properly. Do you think if I add an electronic vacuum pump that I will be able to hold my brakes better and powerbrake to a higher rpm which would increase my launch speed?
I have drilled and slotted rotors with the blazer brake upgrade upfront. But my Malibu does have the small 7/8ths brake booster.
