Power bucket seat lowering
Stupidquestionspro
369
107
Tampa Bay Area
I have an 83 cutlass with I think it’s 6 way power buckets with the old blown up plastic casing motors I intend later to swap for the 3 motor newer style hopefully though in the process I was wondering if anyone knows of a way for me to retain my power seat function but lower the seat I’m “lucky” enough to not be super tall at only 6’ but I have tiny midget legs and a tall torso needless to say with the seat adjusted all the way down my head is probably about an inch from the roof and I often can’t see traffic lights without leaning my head down unless I’m 3-4 cars back as well the sun visors are essentially useless for me.
Any ideas or is it just time for suck it up buttercup?
I would change buckets possibly if I absolutely had to but hoping to avoid it just looking for ideas
Thanks
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
If you lower it to much with a busted gear. you wont be able to take the seat out without doing some damage to it.
Best to remove the seat repair what is broken
Do it right once and forget about it.
Stupidquestionspro
369
107
Tampa Bay Area
Well no it was lowered as far as the power seat was allowed prior to the power seat transmission exploding but what I am asking is once I fix it is there anyway to modify it to make it even lower and retain power seats once I fix the issue because even as low as it goes still isn’t low enough.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
With it lowered in its lowest spot now.
Are you even able to remove the seat?
My Cutlass power seat was in its lowest spot I could barely get a wrench under there to get it out.
I got the front bolts out and had to bend the seat tracks back.
So to answer your question, No i don't believe they can go any lower if the original is in it's lowest position.
Stupidquestionspro
369
107
Tampa Bay Area
I haven’t tried to removed yet because I don’t have the correct parts but I hope I can remove it.
That’s a shame I was hoping to not have to duck anymore oh well I guess hopefully someone has other ideas
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Put a sunroof in and raise the seat
Stupidquestionspro
369
107
Tampa Bay Area
Maybe I need to bust out my sawsall
565bbchevy
9,613
12,680
Michigan
The lowest setting on a power seat is probably as low as you are going to get for any set up, if you have some welding and fabrication skills you could modify your floorboards to move the mounts down and then reinforce them.
Stupidquestionspro
369
107
Tampa Bay Area
Well then I’m done for I have a welder but.... my skills with it leave ALOT to be desired unfortunately.
565bbchevy
9,613
12,680
Michigan
Well then I’m done for I have a welder but.... my skills with it leave A LOT to be desired unfortunately
If you can live without the power unit you could fabricate some brackets that mount directly to the seats but you would lack adjustability.
