- Feb 22, 2015
- 18
- 1
Maybe someone can help me with this because I'm stumped. When i got my 83 Hurst the former owner had apparently lost or poorly adjusted the mechanicals for the power steering pump and put several washers between the bracket and the block, presumably to line up the pulley. I figured there was a spacer in there they lost so they tried to fix it with washers. Anyway, that belt squeaks all the time and drives me nuts so I'm trying to figure out if a) there is indeed a spacer that goes in between the bracket and the block and b) if so, how can I get another one online? Local boneyards have been bare of 307's so I'm looking online unsuccessfully. Or, if someone can give me the proper dimensions of a spacer on their engine I can fabricate one myself.
Thank you!
Thank you!
