Power steering pump hitting power steering gearbox
GPspeed
n00b
Mar 1, 2020
4
Hey guys I have a 1986 Pontiac Grand Prix, it previously had a Worn out 350 sbc and over the winter I built a more powerful 350 sbc for it. I decided to switch to solid motor mounts from speedway motors. Everything fits fine except the power steering pump pulley hits the power steering gear box. The motor mounts drop the motor about 2in. Anyone sealed with this problem before?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
The solid motor mounts you bought are lower than the factory mounts
565bbchevy
9,609
12,663
Michigan
2" drop on the engine is quite a lot what mounts did you buy from Speedway?
I would also worry about other issues like headers, drivetrain angle, etc with that drop.
  • Indifferent
GPspeed
n00b
Mar 1, 2020
4
They are a universal fit so I suspect that’s the problem, the headers weren’t easy they went in.
565bbchevy
9,609
12,663
Michigan
I suspect this drop up front will raise the tail end of the transmission up.
IMO I would change those out for Moroso solids or something similar and save yourself from having other issues.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Solid mounts come in 3 different heights
Speedway Motors suxx either way
All they sell is misleading garbage
bracketchev1221
1,403
1,630
For a street car, put the poly urethane block in in place of the rubber and use the factory mounts.
GPspeed
n00b
Mar 1, 2020
4
Which motor mounts did you get from them? Would love a link, thanks for the help!
565bbchevy
9,609
12,663
Michigan
I ordered Moroso 62630 mounts for the frame and 62515 for the engine. These were specified by Lemons Headers for the headers they made for me.
