power steering pump
flyin brian
10
i have a 78 malibu just put big block in wondering what power steering pump i can use, thanks
pagrunt
9,167
15,342
Elderton, Pa
As long as you have the stock steering box you'll need the one for flaired ends. Try a GM set up from a late '70's truck unless you can find a mid '70's car set up (Caprice/Impala wagons up to '76 would be the most likely source.) If you go with a later set up you can just get an adapter for a flair bo to an O ring hose.
