1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Power steering trouble.
Discussion in 'Engine / Swaps etc.' started by 78elco, Nov 14, 2017.
  1. 78elco
    78elco Not-quite-so-new-guy
    Nov 14, 2017
    11
    I have a 78 El Camino with a 350 and turbo 350 transmission. I replaced the power steering gearbox with the 4 bolt top 800 series box, and also replaced the pressure line/return line, and a reman power steering pump. I went through the process of bleeding the system, and got to a point where there are no more bubbles. With the car started the power steering fluid begins to smoke from the reservoir and the pump gets really hot within a minute or two. When this happened at first I thought I had gotten a bad reman ps pump, so I took it back in and replaced it with a 2nd pump. Went through the entire process again, and I'm facing the same problem. Has anyone else encountered this? With the front end off the ground I've turned it lock to lock for almost a half hour. This is my first post so hopefully I didn't butcher it too bad, and gave everyone the necessary information.
  2. fleming442
    fleming442 Royal Smart Person
    Dec 26, 2013
    1,365
    872
    Did you take the caps off the lines?
  3. 78elco
    Nov 14, 2017
    11
    Yes, and there is no blockage in the hoses
  4. 78elco
    Nov 14, 2017
    11
    The return hose fitting gets hot at the gear box as well, but not the pressure line. Could this be a blockage somewhere?
  5. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    8,482
    1,864
    Gainesville, Fl
    I can't say I've ever heard of that problem before, nor have I ever encountered it on my own car.
    Is this a used steering box? It sounds to me like the problem is within the box itself.
  6. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,012
    2,662
    Kitchener, Ontario
    it may be the second pump but that is where the problem is, the box doesn't heat up the fluid. When you have the v belt off does the pulley rotate easily?
  7. TURNA
    TURNA Comic Book Super Hero
    Jul 24, 2009
    3,490
    1,507
    Socialist NY
    Who and how is the pulley being pressed on?
    • Like Like x 1
  8. 78elco
    Nov 14, 2017
    11
    I'm suspecting a blockage within the re manufactured ps gear box. I pressed the pulley on with the correct tool, sits where it should and rotates without issue.
  9. TURNA
    Jul 24, 2009
    3,490
    1,507
    Socialist NY
    Put the old box in see what happens.
    • Agree Agree x 1
Loading...
Similar Threads - Power steering trouble Forum Date
1996 Chevy vortec in a 1985 cutlass power steering pump pulley hitting Engine / Swaps etc. Jan 17, 2017
Power Steering Bracket Help Engine / Swaps etc. Dec 21, 2016
Power Steering Bracket for use with headers Engine / Swaps etc. Dec 14, 2015
power steering brackets Engine / Swaps etc. Sep 19, 2015
C6 Corvette Power Steering Pump Engine / Swaps etc. Nov 19, 2014
Share This Page
