Power steering washers/spacers
DJHull
255
232
Lansing, Mi
I am missing spacers/washers to mount my power sterling bracket. Does anyone have these laying around?
Stud timer pointer front cover and back bracket side of block.
buick7332
350
589
N.E. Philadelphia area
Make your own spacers. Get a black pipe nipple and cut it with a hack saw. Clean them up with a file and paint them
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Home Dopey now has a special spacer section in the hardware isle.
Last time I went there I bought just about a pack in every size.
DJHull
255
232
Lansing, Mi
My problem is I do not know the thickness of the spacer/washers. I took it apart over a year ago and now can't find them. Do you know the thickness of these two? 1/4" 1/2"...
melloelky
4,152
9,533
mass
not every car's gonna be the same,different pump types different brackets etc etc start bolting it together put the belts on and stack washers to get a rough idea of there you're @and go from there.
DJHull
255
232
Lansing, Mi
Thanks for the info. LoOKs like I have no other options.
oldsmobile joe
2,067
3,053
mpls
i assume its a olds motor, and my cars are in storage so correct me if I'm wrong, but i think its a three point mounting bracket. where it mounts to the water pump, no spacer but it is a stud it hangs on, where it mounts to the alt bracket, no spacer. where it mounts to the left side of the eng block, possible spacer, about the thickness of the motor mount bracket.
i'm going to the junk yard sunday, i know there is a olds diesel there that i can look at for you.
joe
DJHull
255
232
Lansing, Mi
joe
You are correct. Thank you very much Joe.
oldsmobile joe
2,067
3,053
mpls
Here are some pics from the yard. Its a 4point mounting. Two on the water pump, both studs. The lower stud has a long spacer, 5/8" or its part of the timing tab.
oldsmobile joe
2,067
3,053
mpls
There is one that mounts on the side of the block just in front of the motor mount with spacer, about 3/8". Sorry for the poor pic. Best i could do.
  • Winner
