power window question
jeremyandthemonte
731
149
hello all i am starting to get my wiring together and i have a few questions about the power windows so i have the power window diagram do i the the circuit breaker? or can i just splice into a hot wire? and what hot wire?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you can put the circuit breaker in the spot indicated and run your power from there
fuseboxlayoutcopy-jpg.40988
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
not the fuse on top, the windows circuit breaker fits below the name where it's open
image-jpg.39015
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The power for the windows is not constant, it's switched so they can't be opened without the ignition on. In the first photo the fuse for the gauges is indicated so why not use that wire which is pink/black
jeremyandthemonte
731
149
i found the the wiring harness for the windows and put the fuse and wire to the fuse block. but since i am running the wires to a rocker switch in the dash. i was thinking since i have some gauges that need power can i use the other part of the window power wire that goes into the master switch panel as power since they are only on when the car is on.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the wire to power the gauges is already in the dash so why make it more difficult. Maybe that mud you drove through has effected your thinking process....:D
jeremyandthemonte
731
149
are you talking about factory or aftermarket i have the trio of gauges that mount under the dash kinda like these do i just splice into the normal gauge wire as power?
