The computer basically monitors the emissions to adjust the carb to keep the engine to run "clean" & more efficient, works to operate the lock up feature of the transmission lock up converter. If something with the program is not met, it then trips the check engine light. I pulled mine out of my '81 after it kept shorting out the 39 circuit for the gauges & the original 229 ran better and was used to pass a few new '95 cars for the emissions test. You really won't have to many issues since the 350 you will put in won't use a computer carb. The transmission if still a lock up model can use an after market vacuum operated switch or one sourced from a non computer '80's full size truck.
