Proforged Steering Linkage issue
RegalRegal
133
362
St. Paul, Mn
I have clearance issues between the inner tie rod and crossmember as the steering cycles on the D.S. there seems to be enough on the P.S.
I am running all Proforged parts, this is what I have.
Centerlink 106-10071
Pitman 103-10055
Idler 102-10013
Inner T.R. 104-10020
Borgenson box 800130
Wondering if anybody has used these parts and had similar issues?
I probably could just grind a small amount off material off of the tierod
but thought I wouldn't have to as they were made to fit. or did I make a mistake along the way. I tend to do that from time to time. Thanks
Here is a close up View attachment 196634
With no down pressure.
As I push down on chassis View attachment 196636
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
Red Deer, Northern Montana territory
It looks like the d.s. is in towards the crossmember a little bit but not sure why.
It's like the pitman arm is too long?
or the combo of the new steering box and pitman makes it too long.
Measure both sides from the center link to tie rod link, make sure they are equal, and the length of the pitman arm. I have proforged in my car so I can compare to mine.
oldsmobile joe
2,067
3,053
mpls
Where did the pitman arm come from? Is it new? Did you swap steering boxes and it came with the box?
RegalRegal
133
362
St. Paul, Mn
My tie rods are approx. 17.5" from link to link. My pitman arm is 6.5" center to center. I pulled pitman arr and I lined thing up and it looks like I would need shorter arm but not sure why. What steering box do you have?
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
My tierods are 17.5" but my pitman arm is about 6.25"
My steering box and pitman arm is stock, 1986 cutlass.
xylorex
304
393
New Orleans, LA
borgeson box #800130
proforged:
centerlink # 10610071
Idler arm # 102-10013
pitman arm# 103-10055.
My pitman arm is approx 6.5" center to center
I am using the CPP g-body C5 Corvette spindles, ridetech arms with their bump steer kit
