Mine is 22ish @ front wheel opening C/L & ~24ish @ the rear. Like I've mentioned.... Others might 'lower' theirs. My stuff is
low.
I put a 3" square steel spacer that I use on frame stuff in front of the car in the parking lot. The x-member pushed it around. But, this is why my 25" tall front tires ate through the plastic inner fender-well tops after about 3k miles & why I found asphalt crumbs scattered/remaining in areas possible. It's dug into the road surface on many occasions. The ride is fine as long as the road surface is.
The set-up was just initial to get it going & eliminate the 'grandma' appearance to more of a 'bad-arse Grand-Pop' vibe. Mission accomplished 101%. Now I'm accumulating the parts for better braking + geometry which will also change the height as part of the plan. The 2" drop spindles go away in exchange for 1" drop. The 25" tall 15" front tires go away in exchange for 25.7" tall 18" tires. The front end should come up an additional 1-1.5" (not quite 1.5" by my calcs so about 4" off the road surface @ the x-member center is my hope). This has been slowed by the necessary installation/modification of taller front wheel tubs. Waiting on spindles now & going to mock up a side to verify dimensions.
superbon54, sorry about muddying up your thread.
