Hello all,
I have an '88 Cutlass that had a 455 installed by a previous owner. When done, they removed the A.C. compressor (as is usually done). This, of course, leaves me with an awesome case of the belt squeals. My ultimate intention is to run a serpentine system on the 455 (probably the CVF Racing set-up). I will also be installing an aftermarket A.C., as well. But, for now, I would like to do a proper set-up for a non-A.C. Olds V8.
I have seen some vendors selling a 3 piece bracket for the alternator that places it on the passenger side. What I can't find info on, is whether or not the power steering placement changes at all depending on the A.C. option. Also, would I need to change the pulleys to make this work best? If so, which ones should I get? Please note that I have no intention of messing with the engine, as it runs great. So, I would like to get this done keeping the A.C. spec water pump it currently has.
If more info is needed, let me know.
Thanks in advance for your help,
Paul
Paul
