Here's what I'm working with and the results I've gotten.
'86 regal with a sbc v8 engine and Ceramic header with a full 2 1/4" exhaust pipe to the differential. Vehicle is currently 450lbs heavier than stock and I'm running on 155/80 13 tires with stock rear gearing.
I'm using a dual 1" core aluminum radiator, single 16" electric puller fan with full shroud around radiator. 180 degree t-stat. No heater box or core. 30amp relay with temp sensor that turns the fan on at 195 degrees.
Yesterday it was 90 degrees out and in traffic during the day it stayed around 200 degrees on the digital gauge and got as high as 222. This was doing city driving for about 40 miles and the max of 45mph. Last night cruising, it had cooled down to the 70's and my temps stayed in the 195-232 range. Seemed like it stayed hotter with shorter stops in traffic and cooler ambient temperature. I didn't have any problems at all but wanted to see what comments people had with similar setups. So far I'm happy with the single fan setup.
