The resistor won't hurt anything if it's in series. I imagine that it would go between the ECM and DD input. I'd be leary of throwing 12v to the ECM negative out through anything.
The resistor was the fix. For my application I Ran the check engine wire into the Dakota unit and tapped an additional wire from 12v key on source with a 1k resistor in line. You may also be able to use a light bulb
Sounds like DD needs to update their sh*t beyond standard bulbs. It's 2020, people!!
Damn, this gave me a literal "lightbulb" moment. The SES light I installed into my custom gauge cluster is LED. Been having issues with it staying on and running HP Tuners. It keeps throwing a code saying MIL low voltage. Duh! I'll find a resistor and add it in and see if it works.Great news, thanks!
My DD unit is entirely LED. That's the problem, according to DD: the ECU wants to see more resistance to its monitoring voltage, but the LED is too low ohms. DD also noted the option of using a light bulb, but my general warning light (where fasten seat belt light used to be) is LED too, so it likely wouldn't have fixed it.
