That was the kit I had originally looked at, but started to look at other options when my shaved setup would act up. Mine came with the car and is so old they couldn't tell me much about it. Since mine looks like that already I have been thinking of going this route because I would use it as a double safety. They unlock when you are in proximity for me would only then allow a popper button to function which I thought about doing at the same time was the power windows I have laying aroundLet’s suppose you use the kit on Amazon. What will you do with your steering column interlock? Where will you mount the switch to make it look like it came from the factory that way. What are you gaining by adding a push button? Personally, I despise hacking up original wiring harnesses with El cheapo alarms. It ruins the car. I’ve removed a few systems like this from cars because they drain the battery. It’s your car though, hack it up if you think it’s cool. My 2 cents. Do you want your wiring to look like this?
Search: 1 result found for "AUTHFS1002B"
Shop Automotive Electronic Accessories and Parts for Cars, Trucks & Vehicles at AutoLӧc! We've got you covered for all your door, window, trunk, hood, interior, exterior, lighting and security needs. View our large selection of OEM and aftermarket products including actuators, latches, keyless...
www.autoloc.com
