I will be using a Comp Cams pushrod length checker to measure for pushrod length after I get the measurements can I use a digital caliper to get the pushrod measurements?
If you buy the Comp Hi tech pushrod length checker it is marked in increments so you don't need a caliper.I will be using a Comp Cams pushrod length checker to measure for pushrod length after I get the measurements can I use a digital caliper to get the pushrod measurements?
Yes, the kit has the markings and will not require a dial caliper for measurement, I only have 3 checkers I bought the first 2 for my BBC's and the last one for my SBC in the Regal.I bought the Comp Cams 7705 with the 4 checkers in the kit,will they have the increments ?
