My stock crossmember on my 87 Cutlass 442 will not Bolt up to my 350 Turbo trains that I put in what crossmember can I use that will fit
the turbo 350 trans I used is a short tail the 87 stock crossmember does not reach so what you're telling me I have to find a carIf your car had a 2004r in it originally, you will need a crossmember from a G body that had a th200, th250, or th350.
If it's because you used a long tail th350, there will be modifications needed to driveshaft and crossmember
Yes. The early crossmembers are common as fleas on a dog, and should be cheap
