"Want to increase a 650cfm Quadrajet to a 750cfm? Simply grind some material from the secondary stop lever. If your secondary air valve does not open perpendicular to the air horn, then the airflow is limited. Grind this tang to make sure the air valve fully opens. There were no internal differences between a 650cfm and a 750cfm Quadrajet other than the factory setting that allows the air valve to open all the way on the 750 model."
I am sure someone has done this but is it a noticeable difference or should I swap heads, intake manifold and buy a 750?
