Qa1 adjustment help
Michaelw
n00b
Sep 17, 2018
I have a 79 Malibu with qa1 double adjustment shocks all the way around. I’m needing help on what to set the compression and rebound on the front and back shocks for drag racing. It’s stock suspension setup running a 29x9 tire. Sbc with a glide. I usually footbrake.
bracketchev1221
1,411
1,647
I would set them at the middle and work off from there. You can decide if your problem is then at the front or the rear.
