Qjet Float Height Looks Wrong
Supercharged111
4,908
7,669
Colorado Springs, CO
Being a post-1975 qjet, I see my spec is .420". This is what that looks like measuring from the back of the float.
The float has almost zero travel. What am I doing wrong? I'm bending at the V. I expected the top of the float to be levelish.
Bonnewagon
Rocket Powered Basset Hound
10,539
14,217
Queens, NY
You measure from the top of the float to the top of the bowl surface. Upside down. That way the float drops to the "UP" position.
Bonnewagon
10,539
14,217
Queens, NY
Post the carb number and I will try and look it up. You need to remove the float to bend it properly.
Bonnewagon
10,539
14,217
Queens, NY
Is that one of those '80's truck carbs? 1985? 454? Anyway, I know it is a headache, but you have to bend the float arm at the little "V" where it is weak. You have to "guestimate" how much and then test. A bit more- a bit less- until you get it right. By your pics it is not bent right. It should be kind of level, as you expected.
Supercharged111
4,908
7,669
Yeah it's an 85ish truck carb. That is where I bent the thing, thinking I'll just get a new float and try again?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
do you have a better picture looking down through the primaries?. It may be a shadow but it looks like it has a hump meaning it is an 800 cfm...
  • Informative
Supercharged111
4,908
7,669
Not a CCC carb, but it does have a hump. I don't think the carb number jives with an 800 though?
Mine has the hump, but it also necks down like the 750 in the pic does at the bottom of the primary. I wonder if I'm not getting the clip seated for the float and thus giving it the odd angle?
