Quadrajet Th350 kickdown brackets?
MrSony
6,826
6,730
Des Moines, Iowa
Wondering what you guys are using for the kickdown on the Th350 with a quadrajet. Intake mounted or carb mounted? Store bought or custom fabbed? Need ideas for my Buick 350. Stock intake doesn't have the bolts spaced the right way for an after market intake mounted one, let alone a stock one from a chevy. Buick ones mounted on top of the intake behind the carb like this:
MrSony
6,826
6,730
Des Moines, Iowa
Bump, two months later. :p
Oct 14, 2008
8,819
7,766
Melville,Saskatchewan
As said the stock Olds V8 bracket should work if you are running a QJet, that is where it attaches. I can post a pic if you like.
Turbo Zach
2,534
5,874
We used to have several chevy ones laying around. We would cut up and reweld the factory ones how we needed them. I should have a couple. I can look next time I am at my shop.
MrSony
6,826
6,730
Des Moines, Iowa
The only olds brackets I've ever seen are the ones that hang off the back of the qjet and don't have the extra hole for the kickdown cable that is bigger than the *throttle cable.
L67ss
1,350
420
The bracket that came on my 86 cutlass fit the kick down cable from the 79 regal th350 I had
MrSony
6,826
6,730
Des Moines, Iowa
Please do if you have one handy.
Bar50
1,180
871
Tulsa, OK
Oct 14, 2008
8,819
7,766
Going out there again in the morning, I will take a pic. I may have an extra one.
