Questions about front/rear bumper and clip assembly
Tony1968
2,313
5,099
NW Indiana
I have a question. Is there a specific order for the installation of the front grill and bumper and the rear as well? It's been 4+ years since I removed them. In other words should I install bumper first then plastics? What is the best procedure ? Thanks guys for all the continued help 👍
69hurstolds
8,089
17,292
No particular order, actually. What I have done, is insall the fender to header gaskets on the studs, then header panel, headlights and trim, hood ornament, bumper bar, lower bumper cover, and then the grilles last (grille stops before grilles). I've seen others just build the header and then bolt it on, but to me there's too much there IMO. Easiest just to do the header naked due to being lighter and easier to handle, then finish it on the car.
For the rear, it was bumper bar, license plate pocket, bumper cover, tails, reverse lamps.
EDIT: Nope, I mis-remembered. I recall now I did the license pocket after the bumper bar before the cover. lamps went in last. Corrected.
Tony1968
2,313
5,099
NW Indiana
Thank you
