quick frame notch q
peppers
Jan 29, 2017
76
37
I'm thinking about doing this. I'm looking at the qa1 coil over setup and from the videos on youtube I'm gathering just the upper shock mount is used. so if i narrow the frame in theory could i run some dom tube through the frame and some extra bracing on the inside of the frame where the stock coils would have sit? I'm making my build for hard turns over strait lines so for peace of minded like to add more since on older cars mini tub notch kits come with extra bracing.
also any pictures you guys want to share is appreciated.
-83MONTESS-
4,570
967
Bellevue, Ohio
When I did my frame notch I added bracing but farther back since I still use the coils. If you are 100% dead set on using coil overs I don't see why you couldn't do what you're thinking of.
