Where would I find the Oxygen sensor and Map sensor on a 86 Monte CL? Mechanic wants to charge me ALOT to do these two things and I already found both parts at half the price he said.
Thank you
Patrick
Thank you
Patrick
RebelX said:i checked my Haynes manual n the MAP sensor is located on the pass fenderwell for carb models or on a mounted bracket for tbi models.
the oxygen sensor is located on the exhaust pipes below the engine. prolly somewhere around the transmission. remember to use anti-seize on it when reinstalling or the next time you may have problems removing it.
hope this helps out.
lurchsmalibu said:Don't the threads already come with anti seize already applied?
HUH?????? HOW ELSE WOULD YOU REMOVE ONE?? oxygen sensor for the exhaust pipe....the ones that I have done rescently for friends have all (new) come with anti sieze on the threads.DrRansom442 said:lurchsmalibu said:Don't the threads already come with anti seize already applied?
I don't think so but how many times to you unscrew an o2 sensor?
