Quick performance 9" brake install questions
johnnunez29
174
34
Good evening. in the begining of my frame off resto MCSS 86. I got the frame back from powdercoating and received my QP rear end. i have the brake lines to install but i do not see anywhere to bolt the line block to. how are you guys running these rear ends? i am swapping over to rear c7 disc. tia
565bbchevy
9,362
12,018
Michigan
I drilled and tapped a hole on the third member on a rib for mine in the Monte, I think I added a small L shaped bracket between the two.
johnnunez29
174
34
Any chance you can share a pic of where you did that? I found one video online where he basically made an L bracket that went on one of the third member bolts. I also have the issue of my lines being too long. As they’re made for the drums. Guess that’s my next mission 🤦🏼‍♂️
Built6spdMCSS
3,859
6,574
Florida Beach
You see them stainless band clamps..
565bbchevy
9,362
12,018
Michigan
Sorry I don't have a picture of the block mounting, but I did mock ups with my flex line mounted to the car and moved the rearend up and down to find the best location for the line and block to bend and move with the rearend and it ended up being on a rib at least a few inches from the bolts that mount the third member.
For my lines going from the block to the rear discs I also drilled and tapped the housing and used cushion clamps to secure them/
