Hey guys i installed a QP 9in rear end into my 81 Malibu before i put my car away for the winter.
- I noticed they dont weld brackets on for the bump stops.
- im going to take the rear springs out and jack up the rear end to see if the axle tubes touch the frame.
-The car is still in storage right now but i have a few ideas in mind, maybe put some bump stoppers up in the frame.
Do you think the rear axle will bottom out off a hard launch with a set of 275 slicks?
- 90/10 shocks up front with 50/50 rear shocks stock moog 5598 (v6) front springs & stock rear springs.
- its a 350 sbc iron headed th350 trans b&m holeshot converter 2800-3200 stall 4.30 gear, 375 hp tops
- Also i noticed when you jack up the car with the rear suspension unloaded the comp engineering 3 way adjustable rear shocks almost over extended leaving the springs loose in there perchs, maybe install a set of limiter straps, don't want the springs to pop out.
Any input/suggestions would be great. thanks
