Quick Speedometer Question
ITh4n4tosI
Just got a quick question. What speedometer cable do i need for a 700r4 in a 1981 regal. I guess I don't know what length I need or what, if any, g body came with 700r4 from the factory.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
ITh4n4tosI
oh yeah its already got one in it and hooked up but the cable is shot so I wasn't sure if I had to order it online or if I could get one at a parts store using another vehicle
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Since you have a G with a 700-R4 sitting in it...any chance you would be able/willing to measure your driveshaft, center of u-joint to center of u-joint? I have a driveshaft I already shortened for a 700-R4 and someone is interested to use it in a MC and I want to make sure it is as advertised. Thanks in advance for the data point.
ITh4n4tosI
yeah I can probably do that going to work on it tonight. So no one knows of any factory style one that will work then?
86 Grand prix
305
11
Chocowinity NC
Should be about 49.5" c/c. I used a shaft out of a Safari/Astro van two wheel drive. fit perfect.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
In exchange for your time, here is some data:
The short cables are probably for those cars with cruise control. Pull yours out and measure length. Remove it from the back of the speedometer by pushing the friction ring towards the speedo, then pull back on the cable.
Here are some speedo cable part numbers from RockAuto.com a 1985 Monte Carlo
ATP Part # Y814 {Click Info Link for Alternate/OEM Part Numbers} One of our most popular parts
W/o gear adapter; Cable Length 61.00 inches
Part Image
$9.09
PIONEER Part # CA3008
w/ADAPTER LOWER - 20.00" CABLE - 3.8L - 4.3L - 5.0L; Base Model
$9.83
ATP Part # Y815 {Click Info Link for Alternate/OEM Part Numbers} One of our most popular parts
Upper; W/gear adapter; w/intercon.; Cable Length 80.00 inches
Trans. code THM200-4R; W/o gear adapter; Cable Length 80.00 inches
Part Image
$10.43
ATP Part # Y816 {Click Info Link for Alternate/OEM Part Numbers}
Trans. code THM700-R4/4L60/MD8; W/o gear adapter; Cable with 1 female end; Cable Length 100.00 inches
Part Image
$12.30
ATP Part # Y808 {Click Info Link for Alternate/OEM Part Numbers}
Lower; W/gear adapter; w/intercon.; Cable Length 20.00 inches
Part Image
$12.53
ACDELCO Part # 88959478
CABLE,SPEEDO Upper w/4-SPD AUTO TRANS(MW9); GEAR ADAPTER, FLEX W/CASING, 77.80 IN/1976.12 MM LONG; CC1014
Part Image
$32.79
ACDELCO Part # 88959479
CABLE,SPEEDO Upper w/3-SPD AUTO TRANS(MV9); EXC GEAR ADAPTER; FLEX W/CASING, 83.66 IN/2125 MM LONG; CC1076
CABLE,SPEEDO Upper w/4-SPD AUTO TRANS(MW9); GEAR ADAPTER, FLEX W/CASING, 83.66 IN/2125 MM LONG; CC1131
Here are some part numbers for a 1987 El Camino:
Part Image
$9.09
Upper; W/gear adapter; Cable Length 80.00 inches
Part Image
$10.43
Part Image
$12.30
Part Image
$12.53
ATP Part # Y810 {Click Info Link for Alternate/OEM Part Numbers}
Upper; Trans. code THM700-R4/4L60/MD8; W/gear adapter; Cable Length 120.00 inches
Part Image
$15.25
CABLE,SPEEDO Upper w/3-SPD AUTO TRANS(MV9); GEAR ADAPTER, FLEX W/CASING, 77.80 IN/1976.12 MM LONG; CC1054
Part Image
$32.79
Part Image
$40.79
ITh4n4tosI
Thanks that's what I was looking for. I couldn't seem to find what if any gbody came from the factory with a 700r4. Wasn't sure if they all came with the 200. I'll measure my driveshaft tonight when I go work on the car.
