R-134a oil injector?
Bonnewagon
Lost in the Labyrinth
10,564
14,298
Queens, NY
Anyone use a GOOD yet inexpensive oil injector for R-134a systems? I have had some over-charge situations where the relief valve opened and lost a copious amount of oil. I need to be able to re-introduce the PAG oil easily. Prices are all over the place yet they mostly look the same. I am seeing videos where these guys remove the schraeder valve on the high side, pull vacuum on the low side, jam a rubber tube into the high side port, and stick the other end into a container of PAG, sucking it in. Do they not realize moisture laden air is also being sucked in? Or do they know to deep vacuum all over again? Yikes!
Bitterman
230
190
My local autozone has an oil injector AC tool as a loaner tool. It's a $100 deposit for the tool and I have had success when I have used it. Cant get any more inexpensive than free. Not sure what other chains have for loaner tools but it may be worth a look.
Bonnewagon
10,564
14,298
Queens, NY
As much as I like free, I would be suspicious of what oil was used before I used it. A thorough cleaning would be in order first. I prefer to have my own tools on hand. Borrowing or renting is always at the wrong time anyway. I like this Mastercool unit but I wonder which is best. Using vacuum/pressure to inject oil- or the type that squeezes the oil out as you turn it.
Bitterman
230
190
I completely understand. My experiences are with the you turn it style. It's worked well for me.
ck80
Moderator
Moderator
5,743
9,121
I'd think the vacuum type would be more likely to get closer to the measured amount in, while the turn/plunge you wonder if the exact amount went all the way out or not.
Bonnewagon
10,564
14,298
Queens, NY
My concern is more about allowing air into the already vacuumed down system. The MasterCool instructions seem to address that. Still, you must open the container and add oil or dye. But if you fill it the amount of air is pretty small. I also like being able to just leave the injector attached to my gauge set. Most of the time I am not adding oil but when I need to it will be right there ready to go. This is the arrangement they use. As you can see it is possible to close the valves and work around the oil until needed.
81cutlass
4,649
13,565
Western MN
Bonnewagon
10,564
14,298
Queens, NY
But how would you measure it?
81cutlass
4,649
13,565
Western MN
It's 3oz of oil, how much do you need?
Are you sure it let out copious amounts or was it just mist and seemed like a lot?
