so I'm looking at putting together a parts stash to do an r134 conversion on my '81 Grand Prix, the AC system is literally the original one that came in the car with the Olds diesel. The thing also hasn't worked in literally 25 years. Now I have started looking at parts and part #'s that I'll need and even this guy has a lot of questions....
what am I missing, including the tools I need to do this right. I saw a couple of links and videos that got posted here recently and I remembered that I still need to do this. keep in mind that I'm no HVAC tech but I did take Thermo AND heat transfer in college so that's a start. lol.
- Should I leak test the system before I even get started? I know its leaky. We tried like 20y ago to recharge the system back when you could still get R12 and it wouldn't hold. I would bet that its worse now, and may have introduced corrosion into the system(?) I'm OK with replacing pretty much everything short of tearing into the heater box for the evap core..... Anyone got a decent place to start for leak testing?
- Assuming its one of my easy accessible parts, what really do I actually need to replace? I've read everything from "everything" to "only the drier and o-tube" (if its not leaking)... I figure I'm in for the hoses, drier, tube, adapter fittings/o-rings, probably the compressor since I don't know if its at fault or not, maybe the condenser bc its 40 yo at this point.....
- What were the differences in the AC system between model years does anyone know? I initially thought "well I can just look up PN's for my '87 and that should be OK...." Turns out there are a ton of different part #'s involved. Does that just reflect model years or are there other differences like fittings/hose sizes or what's going on there...
- I know what I'll be "in" for with the parts cost. What else do I need? I figure a r134 bottle, the compressor oil, manifold/gauges, what else? HD vac pump? oil injector pump?
- 12 oclock vs 9 oclock coil? Guessing that means where the electric plugs in?
- Hoses: ACDELCO 1533598 {#19144480, 19191406}
- O-tube: ACDELCO 155754 {#19189768, 88919511}
- Misc: FOUR SEASONS 26777 AC System Seal Kit w/ R12 or R134a Retrofit System
- Drier/Accumulator: GPD 1411326 Tank and Tubes Kit
- Condenser (maybe): APDI/PRO 7014013
- Compressor: ACDELCO 1521764 {#19192411} Professional; w/ Clutch
