Radiator Drain?
rubio9800
242
110
California
Hello everyone,
Not sure, but is this the drain kock ? Trying to replace coolant
sorry for the crappy pic , this is from the driver side looking down.
81 GP 265
not sure if it’s original radiator, looks like it is.
thanks
MrSony
6,828
6,736
Des Moines, Iowa
it should have a petcock on it. All else fails, get a biiiiig deep drain pan and undo the lower rad hose from the water pump and let it flow.
69hurstolds
8,195
17,596
Typically, on G-bodies, there's an opening in the radiator support underneath on the passenger side that allows access to the draincock on the BOTTOM of the radiator.
While that's possible that what you circled is a drain PLUG, I'd check underneath first. Reason is, you can see that the plug seems rather hard to get to.
Circled is where you typically find factory draincocks, like this monte SS pictured here.
Burd
248
233
Detroit
Don’t open it, take the hose off, they usually leak after you mess with them.
69hurstolds
8,195
17,596
I guess they don't leak if you don't have one. :)
But if you ever need one, the GM number is 9437207
