Radiator Petcock replacement size?
g0thiac
939
582
Long story short, the plastic radiator petcock broke in my '88 Caprice, the one with the long end. I believe it's the same one most G Body's use, but I don't know which Dorman replacement to use.
Or is there an alternative metal piece I can use that bolts in? Thx.
g0thiac
939
582
NAPA Part number 605-1375. Hope that helps
Thanks Jorge. I'm gonna see if it fits, or if the threads are stripped. Thinking I might just take it to the rad place too, see if they can seal the hole.
Jorge1958
380
214
Columbia City Oregon
Sure. Should be what your looking for. It is a plastic drain c*ck so if the plug is stripped the bung in the radiator should be metal and shouldn't be stripped. Metal is alot stronger then plastic
g0thiac
939
582
So I went to a local rad repair shop, and they got me the plastic part and installed it within minutes. Honestly, I wish I had of used them before spending $20 at two part stores, because they were special orders which didn't even fit.
Also added a bunch of plastic weld on top of the plug, just to be on the safe side. Never ever using the drain petcock for a radiator change again.
Jorge1958
380
214
Good that u were to get it fixed at a good price. 👍
g0thiac
939
582
For sure, I really appreciate the part number by the way. If someone else I know run's into a similar problem I will definitely share it.
g0thiac
939
582
Sure. Weird that those parts stores didn't have it in stock. I stock 2 of them.
I tried NAPA earlier in the week, but the lady at the counter said their warehouse didn't have any. Luckily, if I had to order the part, the number you gave me had a listing for eBay which would have been an alternative solution probably.
