HELP Radiator questions
Stupidquestionspro
Stupidquestionspro
369
Tampa Bay Area
Does anyone have any experience with this brand or set up?
Would it be worthwhile to do this or the version with the aluminum shroud rather than a new factory aluminum replacement with a mechanical fan?
D
Doug Chahoy
1,991
That low of a price sends up a red flag to me. They don’t list the size of the rows. I’d advise buying the metal shroud with the fans no matter which rad you buy.
Reactions: Stupidquestionspro
Stupidquestionspro
Stupidquestionspro
369
Tampa Bay Area
I figured the shroud would be important and there is a small picture of the 3 rows but yea not listing of size.
The factory replacement I believe is one row of 1 inch tubes.
D
Doug Chahoy
1,991
Alot of members on here have said a 2 row with 1 inch tubes is better than a 3 row with smaller tubes.
Stupidquestionspro
Stupidquestionspro
369
Tampa Bay Area
Yea I’m on a bit of a tight budget which is why I’m not going with other forum recommendations. I’m likely going to get the factory replacement 1 inch radiator unless this with the electric fans
Will do better than factory with mechanical fan
olds307 and 403
olds307 and 403
6,001
Melville,Saskatchewan
Yes, a 2 core with 1" tubes will cool better than a 3 core and probably out cool a Copper/Brass 4 core. I know Macar1993 has a Champion aluminum 4 core rad. It keeps his 10 to 1 403 cool in his 87 Cutlass. It is a ridiculously huge rad. The air flow should be better through a 2 core but the Champion 4 core works very well. The Champion 3 core was marginal with my 8 to 1 Olds 403.
Stupidquestionspro
Stupidquestionspro
369
Tampa Bay Area
So assuming that the only radiators I’ve found really within my budget are the one listed previously or
This with a mechanical fan which would be a better set up or is there a set up within this price range you would recommend?
D
Doug Chahoy
1,991
Are you running a stock or modified drive train? That would make a big difference on what you need.
Stupidquestionspro
Stupidquestionspro
369
Tampa Bay Area
1968 sbo 350 bored .30 over #5 heads HEI lowered compression due to bad piston choice tci th350 and factory rear end.
D
Doug Chahoy
1,991
Doesn’t seem that you’d need better than a stock replacement. Get the best you can for your budget.
