MONTE CARLO Radiator Reservior Boiling
chuckfenn1
117
59
Hey guys need second opinion. Today my 1982 Monte Carlo 305in radiator coolant jug started boiling and spitting out all the water and antifreeze. I check radiator and its not leaking. I parked it let it cool off and added more water and coolant. When I was driving home the engine start rattling and loosing power. Didnt think it would make it home. By the time I drove 10 minutes home the coolant jug was boiling over again. I hope its not blown head gasket or something serious with the engine. YOUR THOUGHTS!!!
pagrunt
9,124
15,255
Elderton, Pa
It could be a thermostat or water pump on the way out or possible blockage in the cooling system.
g0thiac
939
582
If there is no visible leaks, finish your driving for today, and have it cool down for 5-6 hours if you haven't so already.
Then turn on the heat on the dash and fans as much you can, and take off your radiator cap. Start the car for 30 mins or so, and every 5 min rev the 305 up, while squeezing the top rad hose gently.
After throw on the rad cap, shut the motor down and drive it once things have cooled down aight.
If it still boils, replace your stat and repeat my steps. Only after that if no change then see about flushing rad and heater core.
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
Trouble - if the coolant temp gauge is normal or idiot light is not coming on, then head gasket or head.
Sounds like a fabulous time for something other than the 305.
chuckfenn1
117
59
hey guys you wouldnt believe what the cause was!! i noticed my battery gauge wasnt charging so I went to check the alternator area and the belt for alternator, water pump was gone. so I replaced the belt added water and coolant and now its running fine...SMH..
g0thiac
939
582
Damn! Most times it’s not that simple, got lucky there for sure.
