Radiators Sizes
Henry88
Whats the biggest radiator can I put in my 85 Regal? To run my sbc.
bill
2,332
11
38
southside va/lake gaston
All the Gbodys take basically the same size radiators, width wise. The thickness is up to your preference, but the top plate is designed for stock radiators, so if you go with custom made, thicker core units like from griffin, they will fit, but you will have to make or modify the plate to hold it in place...hope this helps. CU162 is the stock replacement at AZ, and should work fine for most street applications.
