radio harness question
pagrunt
9,155
15,321
Elderton, Pa
Yea, they all have the same three plugs. The '86 up 1.5 DIN digital radios have an extra plug for the memory back up, not 100% if the '85 older digital shaft radios used the same one.
johnniep
19
26
13
thanks, right channels went out of the original, going to try to replace it with this one, supposed to be out of a g body , not sure of year or if it works
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
For the most part, all GM 1.5 DIN radios are the same plug configuration up until '88-90ish. The brackets may be different, HOWEVER, it's easy enough to swap them around (put your old brackets on a "new" radio).
If the right channels are out, did you check the balance control? It may have gotten bumped.
johnniep
19
26
13
well...it looks like the power button in this radio I acquired has gone south, as much as I hate too, I guess it will be aftermarket
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Put some Lucas in it!!
