Rally Pac Oil Pressure Sender
LeftLaneOnly
293
486
Im looking for the correct part number for the sending unit please
motor = 72 olds 350
69hurstolds
8,089
17,299
Application? Year of engine doesn't make much difference if it's a modern day Olds V8 block.
I'm assuming it's going in a 79 H/O with 0-60 range?
459417 is the p/n for a 79 H/O as well as other years Olds V8 A/G body. I think it goes all the way back to 1976.
14036243 or 19244933 are supersession numbers for the same sending unit. Aftermarket you may can find a Standard PS-154.
  • Informative
69hurstolds
8,089
17,299
Elbow is p/n 401559 if you need to find one of those.
LeftLaneOnly
293
486
It seems the one i have is a bit short and may not fit I have a dash light sending unit in it now. is there a extension tube needed ?
can someone snap a picture of there's for a visual
and thanks
69hurstolds
YOUR too quick.... thanks again thats the part
69hurstolds
8,089
17,299
If you get the correct elbow and the sending unit, it sits at a 45 degree angle, thereabouts. Should end up looking something like this.
  • Useful
LeftLaneOnly
293
486
I hope the one that’s in there now comes out without n issue
Thanks for the photo perfect
