So, I am in the middle of changing out the clapped out Dana 35 in my grand Cherokee and it has been a less than smooth process.
I picked up a junkyard replacement and the junkyard torched it out of the vehicle that it was in. Normally this wouldn't be an issue, but where the brake lines to the calipers meet is on a block that is welded to the axle. This block has two threaded ports for the brake lines to the calipers, and a welded on hard line goes to a flex line between the body and axle. They torched off this hard line so I have no way to connect the brakes back up to the new axle. I would just cut the block off of the old axle, but the vent line for the differential also goes through this block.
I can probably fix that with some tubing and a tee, but it is an issue that could have been easily avoided.
The other part of my rant is that Chrysler, in their infinite wisdom, decided to use Torx bolts to attach the upper and lower control arms along with the track bar. What moron thought it was a good idea to use a Torx bolt anywhere it would rust.
I don't like Torx anything, but that is a particularly bad place to put one. My old one isn't beyond hope, but the junkyard one was pretty crusty. They are soaking while I try to locate a T55 bit to remove them.
Good times
Good times
