"re-wiring" factory HEI car to run points distributor
Ottawa_LeMans
38
75
Hi guys, here posting my first tech question.
I am swapping engines in the '81 Lemans, and the "new" 327 is set up and timed with points-style distributor (with Crane Cams XR-i)
Original engine had an HEI distributor. To save from buying a new distributor and re-timing, I'm considering running the points distributor.
Trying to figure out which wire I should run to the "+" terminal on the points coil.
From my research it looks like the wire that ran to "BAT" on the old HEI distributor is the "I" wire from ignition switch, which should now run through a ballast resistor and to "+" on the coil if I am reading it correctly.
Here are the diagrams I was using (taken from youtube)
I added the black arrows to show the Ignition switch connection points
HEI wiring:
Points wiring:
Thanks,
Colin
  • Wow
ELCAM
1,121
1,265
The HEI circuit does not use the starter by pass. Straight from the ignition switch to the distributor.
The bottom one looks good, HEI wire to one side of ballast resistor. Other side of ballast resistor to + on coil.
Edited to add use the 12ga HEI wire just put a smaller fuse (5A) in the fuse block.
565bbchevy
9,611
12,670
Michigan
Why waste time going backwards to a points distributor, just buy one of these Ebay Chevy HEI's, I have had one in my Regal for going on 3 years now.
There is nothing hard about timing an engine and a it's lot easier installing an HEI in your SBC than keeping an outdated distributor and having to change points.
Reactions: 4 users
Ottawa_LeMans
38
75
Thanks ELCAM,
I'm not sure what is meant by starter bypass.
Is that something that I will have to change for the points wiring setup?
Colin
ELCAM
1,121
1,265
Thanks ELCAM,
Colin
The wire on the starter by passes the ballast resistor when starting so the coil gets the full 12 volts while starting , Then the coil runs on about 6 volts through the ballast resistor while running.
The HEI does not use this. It's coil runs 12 volts all the time(The dashed line from the starter in the top picture is not there.).
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Why go with a points distributor? Isn't that going backwards, in a sense? Tuning is easier with an HEI. No dwell to set, just set the timing. If you insist on using the old points type distributor, convert to an ignitor, like Pertronix and eliminate points. Using points is old tech. An HEI, or electronic setup will stay in tune much longer. Contact points tend to burn and wear. However, I still retain a vehicle that uses contact points and condenser. I know it sounds hypocritical. but in my case, the engine runs off a 6 volt system. I've tried running a Pertronix ignitor, but it doesn't like using 6 volts, so I went back to points and a CDI box.
Ottawa_LeMans
38
75
The only reason I'm considering points distributor is because the engine is already set up with one. The distributor has got an XR-i electronic kit so it's not true points but would still need a points style coil I believe.
Here is the points-to-ignition unit
Colin
airboatgreg
2,866
3,114
I would stay with the HEI. I just bought a new distributor in the box for $50.00 on Craigslist
Ottawa_LeMans
38
75
Fair enough, the only reason I was going to use points was because the engine was already set up with the distributor. Still considering just going HEI though.
I should have mentioned the distributor has an XR-i points-to-electronic conversion unit so it isn't true points that require the typical set-up procedure and maintenance
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
