Nice job! Where did you get the oldsmobile decals at? I've been hunting for something like that for front calipers but no such luck yet. Also, are they the high heat kind?View attachment 65618 View attachment 65619 View attachment 65620 View attachment 65621 View attachment 65622 I finally got my rear Blazer disc brake swap completed. I have to plumb my Wilwood proportional valve today.
Yes they are high heat. Here's the link to where I got them. I emailed them with specific measurements instead of the standard ones that they sell in their package. I have C5's on the front with a bigger decal.http://www.vinzdecals.com/createcaliper.htmlNice job! Where did you get the oldsmobile decals at? I've been hunting for something like that for front calipers but no such luck yet. Also, are they the high heat kind?
Thanks for the link! I've got the blazer front swap stuff ready to go on my cutlass, this will make it easy since the calipers are sitting in my shed. Or should i call it, the cuTTlass as I'm doing a 5.3 swap and will be putting twins on it.Yes they are high heat. Here's the link to where I got them. I emailed them with specific measurements instead of the standard ones that they sell in their package. I have C5's on the front with a bigger decal.http://www.vinzdecals.com/createcaliper.html
Sorry man....I must have not seen your question. You have to cut the top section of the flange off about where you see the curved step so it will sit flush behind the new backing plate. The bottom 2 holes get drilled out to 3/8" and you have to mark a drill 2 new 3/8" holes for the top. You will also have to relocate your shock which mine already was.I guess my question is invalid...
hey I'm Mr P nice work I;M having hard time finding the blazer disc brake setup can you fine this setup for me.View attachment 65618 View attachment 65619 View attachment 65620 View attachment 65621 View attachment 65622 I finally got my rear Blazer disc brake swap completed. I have to plumb my Wilwood proportional valve today.
