rear brake bleeder
denny
279
116
just finished complete brake lines and calipers and rotors. started to gravity bleed and noticed it's almost impossible to get a wrench (tubing or regular) on the bleeder for the rear. it's recessed a little and with the hose on the tubing wrench will not go on because of the recess where the bleeder is. pulled the hose off and used a 5/16 socket to close the bleeder so i can regroup and maybe get some good ideas on this. i like to pressure bleed as a final but it looks like i'll have to use a socket and rag to catch all the fluid. any ideas? thanks
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
I agree, getting to the rear bleeders are a pain in the *ss.
I've been using a small ratcheting wrench meant to be used for bleeder screws. It actually has a hole in the center of the socket, but I had to enlarge the hole in order to fit a piece of rubber tubing in it. I'll see if I can get you a picture of it.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I just use a 1/4 drive long 5/16 6 point socket and I find it easy even with the wheel on and the GP jacked up a few inches
denny
279
116
hi pontiacgp. i been using the same socket. getting ready for final bleed and would like to avoid the mess that goes without the hose on. i'll stare at it for a few more days then make a move. thanks for repy
denny
279
116
thanks for the reply. that sounds like what i need. getting ready to bleed this project out and it goes better with the rubber tube on it. not as much of a mess.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you can use speed bleeders and I used a clear line so I can see if any air bubble are still present
Longroof79
Oct 14, 2008
12,176
9,778
Gainesville, Fl
I have a pair of speed bleeders for the rears that I'm yet to install, already have them up front. I think that would be a better solution in the long run.
