Rear brake hose frame to rear help.
Tony1968
2,323
5,127
NW Indiana
It's been over a year since I took old one off and over 20 years since I installed a new one and for the life of me I can't figure this out. Any help is greatly appreciated. In pics you can see I put those through the frame and installed the retaining clip but it just flops around. What the HE double hockey stick am I missing?
69hurstolds
8,195
17,595
Wait....doesn't the hose slip through the hold from the fitting side until it stops on the ledge, then you put the retainer on?
Take retainer off. Place hose up through hole from the bottom side until it stops, then put retainer on top side to sandwich in place. I'm used to spring clips.
69hurstolds
8,195
17,595
Or is that round looking washer thing the backstop?
Tony1968
2,323
5,127
NW Indiana
That's the thing! I slid it in from underneath and put clip in on top but it still can be pushed up thru. Man am I confused
melloelky
4,160
9,568
mass
If you didn't mess with that hole in the frame,I'd say try a different hose.
melloelky
4,160
9,568
mass
That hose should fall in place,stop and place spring clip on opposing side.
Tony1968
2,323
5,127
NW Indiana
Figured it out. You are correct. the clip goes on opposite side. I'm just missing another "clip" that retains it on other side to the frame
