Rear coil springs - constant or variable?
Tomeal
Tomeal
Apr 17, 2016
76
39
8
Clyde,pa
#1
Been looking at to much info on springs! Give me pro's and con's for both or either.
Help me clear my mind!
David.C
David.C
123
177
#2
Here's the deal... If you are looking for a smother/softer ride go with a consistent rate spring and nice shocks. If you're going to be hot roding it you'll need to bag the rear coils because it will load up the right rear if you are making HP. Or you can add a anti roll bar, more expensive but more effective (about $350). Variable rate springs are generally made from a little thicker material and will ride stiffer (and taller) until loaded (kinda like a truck).
Tomeal
Tomeal
Apr 17, 2016
76
39
8
Clyde,pa
#3
That was my take away from all the spring info.
Now in a 5th gen ElCo, my question is when would I be flirting with too much spring. Also this will not be used in a race application. More of a driver. I may in the future consider light towing.
David.C
David.C
123
177
#4
If it's only light towing just stay with a constant rate spring, I think you'll be happier in the end (more like a daily driver). You can still bag the rear coils to assist with spring compression if needed. If you decide to go with the variable rate spring, let me know. I have 2 nearly new pairs of Moog springs (w/ spring insulators) that I'll let go cheap, plus shipping.
Tomeal
Tomeal
Apr 17, 2016
76
39
8
Clyde,pa
#5
Tomeal
Tomeal
Apr 17, 2016
76
39
8
Clyde,pa
#7
I'll take a pair. I will message you my address. You don't need to be in a big rush to ship them, if you want. I won't need them for a bit. Gotta finish the rear end before I hang it.
