Rear Control Arms
mikester
2,921
3,687
Small town NY
Ive got my wagon up on stands and Im getting ready to yank the rear out. Ive been looking at the different options as far as control arms. Leaning towards the UMI non adjustable tubulars since its for the wagon and Im not going to be beating the crap out of it.
What about the extra reinforcement bars ? I have them in my coupe but thats all Hotchkis. Should I bother ? I see the UMI reinforcement bars are adjustable. Should I look for a non adjustable set instead ? Whats everyone think ?
You folks always have good advice.
melloelky
4,161
9,568
mass
you're on the rite track,if you're not concerned about changing pinion angle then stick with the non-adjustable arms.keeping it simple is best..everyone's different,i think any time you can triangulate something it'll make it stronger,i think the only reason those braces are adjustable is to compensate for "manufacturing tolerances" between chassis'/fitment etc.i can't imagine they're adjustable to introduce a large amount of pre-load into that section of chassis.my .02 i like them
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
I was under the impression that the upper frame mounts should remain flexible, either through the use of rod ends/roto joints or flimsy factory arms..... The Speedway arms look beefy in that area; how do they ride?
timo22
550
1,072
St. Louis,Mo
If you are looking for a less expensive solution , you might consider lower rear control arms out of a 2000 or so Camaro or Firebird. They are the same size as Gbodys and can be had pretty much rust free with 20 year newer bushings . A great candidate for boxing yourself..
timo22
  • Informative
Wraith
1,602
4,764
DFW, TX
I can't say how they ride, maybe in 2019 or 2020 lol. I did use roto joints from Speedway on the uppers though.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you are correct, here is an upper from a G body that we boxed just to see if it helped with lap times. The hole was a 1/2" round when we started....
  • Informative
mikester
2,921
3,687
Small town NY
I think I'll just use the non adjustable tubular arms from UMI without the extra reinforcement bars. I didnt want the adjustable reinforcement bars to begin with and the four new arms will probably be an improvement over the originals anyway. I even considered buying the extra bars from BMR but since I need to spend a little more on parts I figured I'd just do without them.
Zspoiler
Jun 3, 2018
85
55
I have Hotchkiss non adjustable trailing arms on mu 1981 El Camino with now issues. There is a kit out there to box your stock ones for about $20.00 from Original Parts Group .For another option.
