I'm having trouble figuring out the rear gear ratio. My manual for the car says the code on the left side of the axel should start with 2 letters, but mine says this "8AH 0 127". It doesn't follow the format it gives as "the standard" for rear axles.
If I look up AH it gives 2.29 as the gear ratio, but with it not having the same format I was curious if it is correct.
